3-4 shift
Old 06-11-2005, 09:16 PM
what a rush!
moregrip's Avatar
Originally Posted by KySilverado
I guess the point I was trying to make was how often would you be at WOT and need another gear. I was thinking that I've never had occasion to be WOT and run out of rpm. I'm still thinking I would be at about 115 mph in 3rd at 4600 rpm. RPM calculator I just checked puts me at 151 mph @ 6000 rpm with my gears, and tire size.
Like I said I must me having a stupid moment.....
Anyway my shift rpm vs shift for 3-4 is at 8192. The shift speed vs shift for 3-4 shift is at 255 mph.
my shift rpm vs shift for 3-4 is at 8192 & my shift speed vs shift for 3-4 shift is set at 75 mph.
here's my problem, At WOT it shifts to 4th @ 4600rpm everytime, in other words, I can't take 3rd any farther rpm wise than this 4600rpm because it shifts on me. I'm trying to stay in 3rd longer at WOT, as of right now, the only way I can do that is if I'm in D3.
Old 06-11-2005, 09:20 PM
Former Moderator :(
Crash Dummy's Avatar
I think it may be a template problem in the trans file send a E mail to HP Tuners and see if they can fix it
Old 06-11-2005, 09:22 PM
what a rush!
moregrip's Avatar
whats a template problem?
Old 06-11-2005, 09:28 PM
Former Moderator :(
Its just the templates that ls1 edit and HP tuners use to convert there software to read a gm file. I run into this stuff every now and then If it does not look like it should be, check because its most likely not.
Old 06-11-2005, 09:30 PM
KySilverado's Avatar
Set your shift speed vs shift for 3-4 to 255. See what that does.
Old 06-11-2005, 09:36 PM
what a rush!
moregrip's Avatar
thanks
email sent, although, I still don't quite get it.
fwiw, I haven't changed these settings.
what a rush!
moregrip's Avatar
WILCO
Old 06-11-2005, 09:46 PM
zippy's Avatar
i always program them for a shift into 4th. the entire trans programming needs to be changed anyway when you start programming. both the stock and radix tune have only mildly acceptable programs for the trans. one of the SS's i've programed has been to about 140 running 4th gear with no problem and with your truck having the 80E there is no reason to not use 4th at wide open. you just need the programming to be correct. if you're using HPT i can help you fix it to be correct.
Old 06-11-2005, 09:48 PM
what a rush!
moregrip's Avatar
thanks zippy, yes, I have HPTuners. what should I do?
Old 06-11-2005, 09:52 PM
Eye-P's Avatar
just enter your 6400 value and thats it.
Quick Reply: 3-4 shift
