3-4 shift
#22
Originally Posted by moregrip
thanks zippy, yes, I have HPTuners. what should I do?
#23
Originally Posted by KySilverado
I think the answer will be. Set your WOT Shift RPM vs shift to what RPM you want to shift into 4th say 6400 rpm. Then set your shift speed vs shift to close to what MPH you would be doing at 6400 rpm in 3rd. Assuming your 4l80E can take WOT shifting into 4th. I have no experience obviously but if Zippy says so I believe it.
lol, its shifting WOT now and it seems to be alright.
#24
why 6400 and where?
This table is WOT Shift RPM vs. Shift- Normal. I would also change the performance tab to match the normal tab.
Your entire trans properties file should be stock, except for: removal of TQM; change of shift RPM; shift speed(mph). All other tables should be stock due to the Transgo.
