3.42 to 3.73 info
3.42 to 3.73 info
Those of you guys that switched from 3.42 to 3.73 gears what kind of acceleration gain did you notice? Was it a noticeable gain, If you tested the difference on the track what reduction in E.T. did you notice? Did it seem like a different truck? Also can you use the HPP3 to re-adjust the spedo for the new 3.73's, because when I tuned my truck many times with the HPP3 I noticed that there was a gear ratio section that I passed up each time because I hadn't messed with the stock 3.42's. Just really can't wait for the gears to show up at my door that I ordered, hopefully it will be my most noticeable performance mod yet.
I don't think the change from 3.42 to 3.73 is worth the trouble,if you are going to the expense of a gear change go with a 4.10 and a Eaton or Auburn Pro differential.
KINGCYCLES
10-02-2015 10:21 AM
