3 bar fuel pressure regulator
Old 11-10-2008, 09:35 PM
  #21
phasemaster1's Avatar
Originally Posted by thunder550
Dropped the fuel pressure to somewhere around 43-44 psi. The pitch of the pump increased quite a bit. My 96# injectors were rated 96 lb/hr at 3 bar, so I had them in the tune as about 110 lb/hr to match the 4 bar fuel pressure. I just turned the pressure down, changed the IFR table back to 96 lb/hr, and everything worked fine without having to tweak any of the airflow tables at all. Very simple At 5600 RPM and 10psi I'm still only seeing 51% IDC max, lol.
What was your IDC before?
Old 11-10-2008, 09:40 PM
  #22
High on diesel fumes
thunder550's Avatar
At the identical boost level, RPM, and AFR my max before was 41%. Looks like it added about 10% to the duty cycle.
Question for those who have studied this....if I drop my fuel pressure by 25% but it only raises my IDC by 10%, does that mean I gained a significant amount of efficiency?
Old 11-10-2008, 09:46 PM
  #23
Stoichiometric's Avatar
I think that would depend on how much fuel the injector can deliver at each pressure. The fuel delivery curve of the injector might not be linear.
Old 11-10-2008, 09:52 PM
  #24
thunder550's Avatar
Then I'm likely in a more efficient part of the curve right? Or something like that?
If the curve is not linear, but my calculated IFR at 4 bar was linear, then this should also remove a lot of "noise" from my tuning. Sounds like it's a good deal all around.
Old 11-10-2008, 09:56 PM
  #25
I guess I would say yes. I don't really know what's happening but I'll give you an answer anyway
Old 11-10-2008, 09:58 PM
  #26
thunder550's Avatar
Thanks, that makes me feel better
Old 11-11-2008, 11:46 AM
  #27
PT's Slowest Truck
budhayes3's Avatar
What is the reasoning behind the factory running such high fuel pressure? Is it for better fuel atomization?
Old 11-11-2008, 11:55 AM
  #28
PSM
PSM's Avatar
I would assume so. Look at what the direct injection gas a nd diesel trucks run for pressure
Old 11-11-2008, 12:26 PM
  #29
Moderately Differentiated
dewmanshu's Avatar
That plus I'd imagine they have some guidelines ro goals to meet for injector costs. Just running a higher pressure rate keeps them within their guidelines without having to increase the injector size. I just made that up on the spot but sounds good to me.
I am quiet surprised thunder you hadn't locked onto this much earlier. I have always contemplated doing it just see if the moto 60's were any easier to idle tune.
Old 11-11-2008, 12:33 PM
  #30
PSM
PSM's Avatar
They new ZR-1 uses 48 lb/hr injectors and goes from 36psi at idle to 87psi at higher rpms
Quick Reply: 3 bar fuel pressure regulator
