300rwhp can it be done ....
#21
I have!
Just bolt-ons, on my 5.3L 3.73s
With:
K&N PFIK Cold Air
TB Coolant Bypass
Mobil 1 Full-Synthetic Engine Oil
Nelson Performance Custom 93 Tune!!
180 Thermostat
NGK TR55 Spark Plugs
MSD 8.5mm Wires
LS1 Electric Fans
Flex-a-lite VSC
ASP Underdrive Crank Pulley
AC Delco 150A Alternator
Pacesetter Long Tube Headers
Pacesetter 3" Catless Y-Pipe
40 Series Flowmaster
Oh ya, and a touch of lean!
With:
K&N PFIK Cold Air
TB Coolant Bypass
180 Thermostat
MSD 8.5mm Wires
LS1 Electric Fans
Flex-a-lite VSC
#22
11 Second Club
6spd or auto
Originally Posted by 1TRUESS
I have!
With:
K&N PFIK Cold Air
TB Coolant Bypass
180 Thermostat
MSD 8.5mm Wires
LS1 Electric Fans
Flex-a-lite VSC
With:
K&N PFIK Cold Air
TB Coolant Bypass
180 Thermostat
MSD 8.5mm Wires
LS1 Electric Fans
Flex-a-lite VSC
#26
Today i made 280.02 hp and292.27 tq.This was after i had installed a stall which lowers your power to wheels a decent bit as everyone knows.We retuned the truck and got about 6 extra hp over the base line pulls.My numbers before the verter where 288.97 hp and 307.66 tq.
So if i was just tryin to hit a number with a stock verter and a short belt i could ahve over 300 no problem.
O yea my base pull compared to before the verter was like i said 288.97hp today with the verter base pulls i was at 274.xxhp...So the verter caused a decent drop as well as my tq came down to 283.xx
Like i said if i was worried about a number stock verter and short belt would get me there.
BTW:This was done at 95.25degrees and 24%humidity.
#29
Dyno testing with the converter locked will help reduce drivetrain losses.
If an Ls1 can dyno at 290-325 rwhp stock, than I think a 5.3 should be able to hit 300 rwhp with bolt ons and tuning.
An aluminum block L33 with its slightly different heads, cam and compression ratio should be able to hit the mark a tad easier than an iron block LM7 5.3.
Keep trying, someone will get there.
peace
Hog
peace
Hog
#30
11 Second Club
peace
Hog
peace
Hog
