305 intake same as vortec 350?
Hey guys,
Looking at buying a cheap '97 ECSB with the 5.0L and then swapping in the L31 shortblock and some vortec heads. Are the intake manifolds and throttle bodies the same? I would also need to get an ECU for an L31 right? I'm thinking everything else can be transferred from the 305 to the 350. So the list of things I need would be:
L31 shortblock
vortec heads...the 305 uses smaller valves and combustion chamber
intake manifold and throttlebody unless it's the same as the 305
bigger (19#) fuel injectors?
stock L31 ECU
Let me know if I missed anything.
TIA!
L31 shortblock
stock L31 ECU
TIA!
I remember lookin around for l31 stuff back when i was doing the efi conversion on the dune buggy. I don't think the manifold/tb is the same, I could be wrong though. I'd just buy an aftermarket intake or maybe could you use an LT1 intake? what're your plans for the motor?
No plans for the motor really. I just want a reliable setup with the power of the 350. I figure I can get the truck cheap and then spend maybe $2K tops on the L31 swap and I'll basically have a new motor. Only mods I would do down the road are maybe CAI and a catback.
