from 317's and truck intake to L92's... whats gotta be done?
Old 12-17-2010 | 01:02 AM
denali_on_26's's Avatar
From: Where our street cars are faster than your racecars..Mississippi
Question from 317's and truck intake to L92's... whats gotta be done?
i have a stock truck intake and 80# siemens deka injectors with stock fuel rails.. and i am thinking about switching over to the L92 heads.. EXACTLY what all is needed for this swap..
with the new intake accept my DBW t-body? will the rails fit my injectors? ECT, ECT...
Old 12-17-2010 | 01:41 AM
SLOXCAB's Avatar
what intake are you gonne run?
Old 12-17-2010 | 02:13 AM
nickleahy23's Avatar
id like to know as well..I might be pullin my lq4 this spring and rebuilding it...was thinking of upgrading intake and heads while im at it..
Old 12-17-2010 | 02:28 AM
Atomic's Avatar
I have a gauge for that
Off the top of my head you will need new injectors orings since the gen4 stuff is slightly bigger on the bottom side, I got mine from fuelinjectorconnection. Will need and 87 or 90mm 4bolt tb and right adapter harness. It would be much easier to find a complete intake and just swap injectors and change orings and get the drx harness.
Old 12-17-2010 | 02:30 AM
SLOXCAB's Avatar
then theres the fun of accesorry stuff
Old 12-17-2010 | 02:32 AM
SLOXCAB's Avatar
heres from when skeet did his stuff what you would need if you ran a car style intake
Old 12-17-2010 | 08:54 AM
new injectors?
my deka 80's wont work man this cheap swap is looking REAL expensive...
new T-body? DRX harness?
how much is all this?
sounding like alot of for OEM
Old 12-17-2010 | 08:59 AM
Bumpers's Avatar
The dr.x harness is 225..
Old 12-17-2010 | 09:14 AM
I was thinking about this swap when I put the 6.0 in but not sure because by the time you buy heads,intake,injectors,throttle body and the harnesses it will all add up to a good size chunk of change. I will probably just use the 317s or maybe get a set of 243s and maybe a tbss intake or something.
Old 12-17-2010 | 10:05 AM
skyhighsami's Avatar
no title here
Why not have your 317s worked and maybe a Fast intake?
