3500 Auxiliary Fuel Tank on a 1500
Old 08-14-2007 | 10:25 PM
xXxSilveradoxXx's Avatar
Default 3500 Auxiliary Fuel Tank on a 1500
Has anybody installed an auxiliary fuel tank in place of the spare tire? I’ve seen a factory auxiliary tank there on the 3500 flatbeds. I’m thinking about installing one and using it instead of the factory tank. What would be needed for this? I crawled under one today and looked it over, it looks like I’d need to fab up some mounts but it doesn’t look like too much of a bitch to do. Any info will be appreciated!
Old 08-14-2007 | 10:30 PM
nightrunner's Avatar
Mr. Obvious
never heard of this before....
this would be awesome for weight transfer!! and cut out the cost of having a custom tank built
Old 08-15-2007 | 12:22 AM
True that! I just about gave up on the idea of having a rear mounted tank until a flatbed 3500 passed me yesterday and I saw it! I'm halfway tempted to just jump into the swap but I'd like some information if I can get it first. Either way I will do a write-up.
Old 08-22-2007 | 11:32 PM
I am pretty sure it is just a matter of swapping in all of the parts and then flashing the pcm with the 3500 hd tune. The pcm monitors the fuel level in the tanks and then automatically switches over when it gets to a certain level and activates the pump in the auxiliary tank while shutting down the main pump.
Old 08-23-2007 | 09:30 AM
SS_bnoon_SS's Avatar
Of course there's no reason you couldn't wire up a manual switch to relays from one pump to the other...
I just noticed that the truck in question is an '02 though... Is '02 a return fuel system??? How would you make the second tank return fuel to it and not the main tank? You could run separate lines, but you would still have to have a common rail and it would return to both tanks... hummmmmmmmm
Zizzle
10-19-2017 09:44 PM
chopperloco
07-10-2016 11:45 PM
ss454327
10-17-2015 04:43 PM
thunder550
10-08-2015 05:53 PM
ss4chad
08-15-2015 03:25 AM
