383 is running now I have a problem Help Motor guys please help
Originally Posted by AintNoHo
Just so you're completely confused now, the problem is not timing or plugs, it's too rich. The unburned fuel from the cylinder is continuing to burn in the headers. That's why the heads are cool while the pipes are red hot. I've done it while trying to make an fmu work. In addition to red hot pipes, flames would shoot out the open exhaust on let-up from a full- throttle blast. If it was too lean, the pipes would be normal but the heads and pistons would overheat and ping. In any case, let us know what you find.
I am going today to give it another try. I have had to work so I havent been able to go and work on it. I will have a report tonight. tHanks for the help guys!
lxcoupe
07-21-2015 02:12 AM
