383 starts and dies
#41
I did an intake swap for a local guy (TBSS intake on a 1999) he had the retuned pcm shipped to me before he brought the truck over for the swap, after swapping everything over the engine would only run about a second that stall. (even with stepping on gas) at first I thought it was a security or crank relearn problem, but ruled those out. After going through everything and checking all the connectors I noticed that the MAF was not plugged it, plugged it in and the truck fired up and ran just fine.
#42
I've unhooked my MAF before, it runs just a hair rich, but still runs just fine. Maybe it's a problem of custom tune vs. stock tune?
Anyway... I'm glad this got figured out and wasn't anything major. I think we're all about as excited as you are to see this project finished.
#43
the reason its not running without both connected is because the computer has had no learning time. once the computer figures out the tune/engine i could run without the map or the maf.
#47
ill have it on tomorrow but my issue has been i cant find any info on whether or not the wiring on my trucks harness the same as the 07" map sensor. it it is ill have it on in a matter of minutes
#50
Charlie is a good tuner but getting everything right in a mail-order tune without logging anything is a pretty big crap shoot. I'd be surprised if 20 percent of all mail order tunes ran decently with that many mods. You need to get it to a tuner who can work with the car in person.
