4* cam advance, HELL YEA!!!!!!!
Old 09-26-2004 | 08:16 AM
Originally Posted by RED2K
Did you have to buy a after market timing chain set to be able to advance it? can you advance it with a stock chain set up
Yes you can advance your cam with the stock timing chain. Each tooth you advance the cam on the crank is 4*. Each tooth you advance the cam its self is 1/4* i believe. So degreeing a cam is pretty easy overall.
Simular to the subject, if you have a cam that is too big you can advance it and lower the powerband. If the cam is too small you can retard it to gain some power up high. I am thinking about retarding the cam in my Blazer to get some topend out of it.
Old 09-26-2004 | 09:09 AM
Flyer's Avatar
Advancing the cam is turning it clockwise??
Old 09-26-2004 | 09:26 AM
clockwise as you face the engine is advance.
Old 09-26-2004 | 09:48 AM
Sport Side's Avatar
Here's some help to this topic.
Big Tex wrote:
If you have too much exhaust duration for your setup hurting your torque, advancing the cam will just add to the problem.
He is speaking of how you are closing the valves sooner.
Look thru this thread if you haven't already.
Camshaft-advancing
OHsixLS3
08-10-2015 07:19 PM
noproblems209
08-10-2015 06:57 PM
Hmguyton
08-09-2015 05:38 PM
JordanH
08-08-2015 07:59 PM
Quick Reply: 4* cam advance, HELL YEA!!!!!!!
