4.060" bore why or why not.
Old 02-21-2010, 11:19 PM
  #21
9 Second Truck Club
stock48's Avatar
The older blocks had bad core shift and some couldnt be bored .06 over. Its a good idea to get the blocked checked after boring it that much. Ive said it before, if you want to get a long life out of a stroker go with an aluminum block. The cylinder skirts are deeper and stabilize the piston more, therefore less oil burning. When/if I do another stroker it will be out of an LS3 block.
I feel the same way on the longer sleeves.
Originally Posted by dug
supposedly its possible to bore out to 4.080 if you sonic testing the block.
It's allways a good idea to sonic test due to possible core shift, and inconsistant castings. 2 out of the last 3 iron 6.0L blocks I sonic tested would easily take a +.100'' over bore frr a NA application.
Old 02-23-2010, 05:24 PM
  #22
dug
Banned
dug's Avatar
Wow, I didnt know they could be bored over +.100" . Could a good block make it to .125" over?
lukn4trbl355
10-21-2015 11:19 PM
Wolftrk99
10-02-2015 08:17 AM
01silvy
09-26-2015 10:20 PM
LT-1 SS
09-26-2015 05:19 AM
Goat's ss
09-22-2015 01:07 PM
Quick Reply: 4.060" bore why or why not.
