4.3 to 5.3 Advice/help needed
I have a 2003 Chevrolet Silverado with a 4.3 v6 under the hood. Just today I purchased a 5.3 v8 with 111k miles out of a 2004 Chevy avalanche. To have a successful swap what would I need to do so?
i have read the very detailed writing about the v6 to a gen3 v8 but that’s for a 4.3 going to 6.0. So I am still curious about some things. We did receive the PCM/computer and the motor mounts off the guy we bought it from. Any advice or help is greatly appreciated
Wiring for the 5.3 is IDENTICAL IN EVERY WAY to that for the 6.0; so all of that writeup stuff is equally applicable.
Since you have the ECM & harness that came on the V8, you should be good to go. There may be acoupla minor details to work through; the TAC for instance (I'm not the least bit acquainted with the 6-cyls, so don't hold me to any kind of standard of accuracy or completeness; but other than that, you're largely in business. The 6.0 swap writeups will cover all of that.
strutaeng (01-24-2024)
I’m assuming still go through acquiring the new fuel lines, ac hoses, heater hoses, radiator hoses, v8 torque converter, flex plate, fan shroud/e fans, the TB bypass for the radiator, air intake.
This one part of the write up confuses me a little
“you will also need a nipple that connects to the back of the intake manifold that provides vacuum for your brake booster, the 6.0 engines power breaks use their power steering pump. you can get this from the dealer or off a 4.8,5.3 intake manifold”
i would not need what is mentioned above because I have a 5.3 motor and intake manifold or am I wrong?
thanks for your time
Ok so since I have the ECM would I still have to get my current PCM reflashed/retuned into v8?
That quote is assuming the 6.0 came from like a 2500 with hydro boost brakes. In your case it came from an Avalanche, which I'm pretty sure has vacuum assist brakes just like your truck, so no issues.
Yes, you'll need your V6 ECU reflashed for the 5.3. I believe the V6 stayed drive by cable for the entire GMT800 generation. Does the 5.3 you got have drive by wire? You got the harness too, right? You'll also need the TAC model and the gas pedal assembly to convert it to drive by wire.
Does the 5.3 has return fuel lines on the intake? Or is it the single fuel line (return less?)
No the v6 is not drive by the cable I heard after 03+ they all became electric and going by that logic the avalanche being an 04 i would assume it’d have electric. I’m a novice when it’s comes to this but it seems the intake has return fuel lines on it due to the smell motor was taken out just today and running 2 days ago. I Can provide pictures if necessary
I do believe the 4.3 eventually got drive by wire but that's on the GMT900s.
Since you have the V8 ECM you don't have to worry about reflashing the 6-cyl one. All that talk is moot.
I’m assuming still go through acquiring the ...
I'd STRONGLY recommend swapping over to HB. It's SO FAR superior to vac assist for brakes, it's like ... no comparison. Especially if all that stuff (apart from the HB itself) came with your new 5.3. Otherwise, go hit yer local buzzard nest, and pry em off of whatever you don't have yet, rather than dinking with vacuum fittings. You'll be glad you did. Mostly you need the HB itself, the hoses if you can get em, and the fluid cooler.
fan shroud/e fans
I did not get the harness ... I do plan on getting a stand alone harness.
I suggest you go to a junkyard and spend some time LOOKING AT trucks before posting any more. We're not going to be able to give you an absolute step-by-step and complete parts list since we can't know what all you actually got with your new motor. Do some research on your own so you can ask intelligent questions instead of floundering in ignorance.
