4.3-5.3 swap 2003 scsb?????
You need to do a DBW conversion, not a big deal. The new pedal bolts in, as does the TAC module. 20 minutes to do that. Use an 03-06 harness and PCM. To control the 09 motor you'll need a Lingenfelter box to convert the 58x to the 24x crank signal. Tap the block for the old knock sensors, and extend the wires for the cam posistion sensors to the front of the engine.
Than it's just your typical swap stuff, mounts lines, hoses etc. I'm just putting the finishing touches on the V8 swap in my '06
lycominghunter
07-29-2015 04:24 PM
