4.3 5.3 swap is almost complete!! PICS
Old 08-01-2011, 09:39 AM
Custm2500's Rude Friend
1FastBrick's Avatar
What about the computer??? Did you have the original reflashed or are you trying to use the donor pcm from the v8 harness???
Old 08-01-2011, 04:15 PM
kr1s's Avatar
I'm using the donor pcm from the v8 harness
Old 08-01-2011, 04:52 PM
1FastBrick's Avatar
It is in anti theft mode then. It is not recogniseing the donor pcm because it has a different vin number. The body control module does not recognize it
Old 08-01-2011, 06:15 PM
kr1s's Avatar
hmmm ill look into that
Old 08-01-2011, 06:16 PM
1FastBrick's Avatar
You will either have to have the engine calibration flashed into your original pcm or have the donor pcm update with your vin and or have the VATS removed.
Old 08-01-2011, 08:31 PM
Man Motor club
rjwz28's Avatar
How do you remove the VATS?
Old 08-01-2011, 08:33 PM
kr1s's Avatar
getting codes Pcm p1631
and pcm p0118
Old 08-01-2011, 11:42 PM
1FastBrick's Avatar
VATS= Vehical Anti Theft System. It's in the pcm programming has to be removed in the tune.
Old 08-01-2011, 11:58 PM
1FastBrick's Avatar
and pcm p0118
P1631 is a code for the anti theft. Basically its not recognizing the password from the PCM to the BCM as I mentioned before. The PCM and the BCM talk with eachother before allowing the car to start. That's how the anti theft works.
The P0118 is for ect sensor. Electronic Coolant Temp Sensor. Make sure its pluged in all the way. If its truely bad there about 20....
Old 08-02-2011, 02:29 AM
Man Motor club
rjwz28's Avatar
Yeah I know what VATS is, I just wasn't sure if that was purely tune related or otherwise.
Quick Reply: 4.3 5.3 swap is almost complete!! PICS
