4.5L Duramax in the 1500 for 2009!
GM Plans First Light Duty V-8 Clean Diesel for North America
High-efficiency V-8 scheduled for pickup trucks under 8,600 pounds Gross Vehicle Weight and HUMMER H2
Low emissions, high performance and excellent fuel economy
Expected to deliver class-leading torque, power and refinement
Manufactured at the GM Powertrain Tonawanda engine plant
TONAWANDA, N.Y. – General Motors Corp. will introduce a new, state-of-the-art 4.5L V-8 Duramax turbo-diesel that improves engine fuel efficiency by 25 percent, reduces CO 2 emissions by 13 percent and cuts particulates and NO x emissions by at least 90 percent for North American light duty trucks and the HUMMER H2 built after 2009.
The premium V-8 diesel is expected to deliver class-leading torque, power and refinement while maintaining a significant fuel efficiency advantage over comparable-output gasoline engines.
The new dual-overhead cam, four-valve V-8 diesel engine will fit within the same space of a small-block V-8 gasoline engine. This compact size is made possible by using integral cylinder head exhaust manifolds, integral cam cover intake manifolds and a narrow block.
“This new GM light duty diesel is expected to become a favorite among customers who require excellent towing ability and fuel efficiency,” said Tom Stephens, group vice president, GM Global Powertrain and Quality. “It will meet the stringent 2010 emissions standards, and it will be compliant in all 50 states, making it one of the cleanest diesel vehicles ever produced.”
Environmental benefits of the new engine include a 13-percent reduction in CO 2 versus gasoline engines, and at least a 90-percent reduction in particulates and NO x compared to diesel vehicles today. This will be GM’s first engine to use a selective catalytic reduction NO x aftertreatment system with a diesel particulate filter to help achieve the Tier 2 Bin 5 and LEV 2 emissions standards.
Technical highlights of the engine include aluminum cylinder heads with integrated manifolding; a variable-vane turbocharger with intercooling; a Compacted Graphite Iron (CGI) block for a stronger and lighter engine base (compared to lower-strength aluminum or heavier grey cast iron); and fracture-split main bearing caps and connecting rods for a precise fit. An electronically controlled, ultra-high-pressure, common-rail fuel system is used, which has the ability to inject fuel five times per combustion event to control noise and emissions.
“This new V-8 is not only a clean diesel meeting the toughest emissions requirements in North America, it also delivers an effortless performance feel because of its high torque across the speed range,” said Charlie Freese, executive director of GM Powertrain Diesel Engineering. “It is also significantly quieter than other diesels on the road today, with noise and vibration performance approaching gasoline V-8 levels.”
Freese said the new V-8’s compact size enables it to fit in the envelope of a gasoline small-block engine, which provides GM the flexibility to introduce this engine in a wide variety of vehicle applications should there be future market demand.
The premium V-8 diesel engine is expected to deliver class-leading refinement, horsepower and torque and fulfill multiple vehicle applications with ratings in excess of 310 horsepower and 520 lb-ft of torque.
GM (Opel, Saab , Vauxhall and GMDAT ) currently offers 17 diesel engine variants in 45 vehicle lines around the world. GM sells more than one million diesel engines annually, with products that offer a range of choices from the 1.3L four-cylinder diesel engine sold in the Opel Agila and Corsa, up to the 6.6L V-8 Duramax diesel sold in full-size vans, heavy duty pickups and medium duty trucks in the U.S.
GM first introduced the Duramax diesel 6.6L V-8 in the U.S. in the 2001 model year and since then, customer enthusiasm for this heavy duty diesel has been outstanding. In fact, GM’s heavy duty pickup truck market share has jumped nearly tenfold in the six years that Duramax engines have been offered.
Originally Posted by RandomHero
Like everything else. They say they'll come out with it, but it'll never happen. It's kinda sad that GM's "performance truck" is a stock silverado with plastic molding,20's and an engine that only puts out 30 fwhp more than a stock silverado.
Originally Posted by truckmann
I have to agree... GM needs to step up to the plate. It's hard to believe any of those press releases since it never seems to happen.
We have the slowest trucks from the factory(or just about) yet if you want to make a truck fast(excludes factory customs like lightnings) you buy a chevy.
How much is that truck going to cost? 40,000+ for a 1500 diesel. I think your better off getting a 2500. But if they keep the cost down maybe they will sell.
And make them available in everything! How bout a reg. shout bed 4.5L diesel!
no title here
Yea but isn't it funny that everybody picks a silverado to make fast with aftermarket add ons?
