4.8 to 5.3, requirements?
Old 08-23-2005, 09:26 PM
  #21
TURBHOE's Avatar
Originally Posted by mjhoward
Well, one of the sources of info is obviously wrong. ???
yeah thats kinda what i was thinking lol. i would think the second was the off one becouse that would make for a really short piston and probably put the pin up in the oil ring area and i don't think they would do all that just to put a long rod in there doesn't make since to me but i dunno.
Old 08-23-2005, 10:57 PM
  #22
ls1ow's Avatar
but would be the real gain in doing all the work to just gain .5 liters???
Old 08-23-2005, 10:58 PM
  #23
ls1ow's Avatar
i mean is it really worth all the work
Old 08-24-2005, 12:30 AM
  #24
zippy's Avatar
it's a tough call, but if you drive a 4.8L and a 5.3L there is quite a difference. much more torque and a noticable hp difference. mostly just the lower rpm is a ton better.
Old 08-24-2005, 10:16 AM
  #25
Diablo666's Avatar
it's worth the work if you don't want to swap blocks the 5.3 has a lot more torque and more potential i'm not gonna convert my 4.8 to a 5.3 'cause i'm building a stroker LS1 for my lil' devil
Old 08-24-2005, 05:45 PM
  #26
4.8shorty's Avatar
912jonathon, any results from looking up part #s? I think it would be worth it for me because I know my engine's been well taken care of, and changing the engine out would probably still be quite a bit more then the cost too change the crank/rods/pistons. As for power difference, I know on paper the 4.8 doesn't seem much different then the 5.3, but seat of the pants feel says their's a huge difference. That and if every bolt on adds a certain %, then you'd be getting more bang for your buck with the changes. Lastly, a cam would go in before resting the refreshed SB between the frame rails.
Old 08-24-2005, 06:06 PM
  #27
912jonathon's Avatar
no sorry i rebuilt my transmission today only to put it back in a now i have no reverse. i will check first thing in the morning
Old 08-25-2005, 03:41 PM
  #28
sorry, i have had no luck finding any answers. the part #'s are different on the entire bottom end though. i know the 5.3 has a 3.662 stroke and the 4.8 has a 3.268 stroke. my guess is you would have to change the rods and crank, but still not sure about the pistons. if you could use 4.8 pistons it would raise your comp. about 10.00-10.50.1 though. i think the simplist thing to do is just find a good 5.3 or 6.0 and stick it in. i will do more researching tommorrow
Dan Neumann
11
08-07-2022 09:06 AM
JordanH
08-08-2015 07:59 PM
03regcab sierra
20
08-03-2015 12:11 AM
MS3Z
07-30-2015 06:17 PM
06 4.8
07-15-2015 07:17 PM
Quick Reply: 4.8 to 5.3, requirements?
