4.8 to 6.0 swap
4.8 to 6.0 swap
Hey, I'm alittle new to the site. I have a 2000 4.8 RCSB with the nv4500 trany . I just bought a 6.0 (block, heads, and intake) I also just bought the sts turbo set up with the front mount a2a intercooler. My question is for the motor swap.I was hopeing I could just use my pullies,exhaust manifolds, and harness off of my 4.8. I think I may need to get a 6.0 ecm. The motor is from a 2002 gmc. It has the 317 heads on it. I am hoping for a straight forward drop in. I am also hoping that the 5 speed transmission will hold. I will probablly need a crazy clutch. Any info would help Thanks Bryan.
Formerly one92rs
all the accessories from the 4.8 will bolt right on the the 6.0. i would put in a 02 pcm for the 6.0. the only problem will be the tranny. did they offer that with a 6.0. if they didnt then the pcm will not be programmed for it. you might have to use one for a 5.3 or even yours with a custom tune in it. the sponsers should be able to help out. nelson performance can help out i know. he is a sponser>>>>>>>
Suburban2500
07-19-2015 04:50 PM
