4.8 to 8.1 swap... can it be done?
Hey guys I have a 2000 silverado with a 4.8 right now. I was thinking about going with a 6.0, which is the most common around here. Then I thought, hey 8.1 is HUGE. I found one cheap and was wondering how hard it would be to swap out. I was going to swap teh 4l60e to a 4l80e anyways. Would that be the only problem I would run into when swapping it into my 1500? What else would I have to worry about?
definetly not going to be worth doing the 8.1, your first big problem is that the whole front section of the frame will have to be changed to a 2500HD front end, and so many other complications that just doing a 6.0 and a built 4l80e would be far cheaper and better all around...don't get me wrong the 8.1 is a beast, but you need basically all new everything to make it work and it would not be worth the time and money as compared to a 6.0 and 4l80e swap.
-Pete
-Pete
Banned
get a SDPC 632 CI crate motor, 1140hp out of the damn box...throw that in there....a direct port NX setup and run 9s in a truck all day with the right setup behind it.
