4.8 questions
5 year bitches!
Originally Posted by TurboGibbs
Why not? do it. You will need to get the compression up with that cam for sure. Or just count on it not running well unless you spray itl. That would be a bear to be a DD in a 4.8 but would be fun to play with.
It will take a 200 shot about 28 1/8th mile runs.I pilled it to a 225 and burned 4 plugs all of the rear cylinders.
Have to pull the heads tomorrow...I want to beat this motor till the thing starts knocking.
I just rolled 50k miles on it today.
Its easy on the mind when you have a 6.0 waiting to go in it.
I have a 4.8 with a dead #7 cylinder. You can have it fo free if you pay to ship it. It'll give me an excuse to put in the 408.
I think it'll be a fun ride. I think you should get some LS1 heads and mill them to up the compression a bit. You'd be surprised at how well a 4.8 with a too big cam will do with drivability when it's a stick. I don't see why it wouldn't run a solid 12 N/A. I think an 11 might be a bit optimistic, but if you're not affraid to spin the **** out of it, then it might be possible. 11's on juice for sure though.
i like the sound of a destroked 6.0..dont really know on how youd get by with the right length of rods and pin heighth....with a 4.8..you might have the heads milled and take an air grinder to the intake and exhaust ports..or some milled ls6 heads..since you dont care about blowin it up do a 2 stage nitrous kit..100 off the line and 150 in second..should be wicked id think
bbowerman
07-26-2015 10:57 PM
