4.8L w/6.0 milled heads, v3 cam, PS LT's
I have a 2005 silver with the 4.8, and it is getting heads off of a 6.0 that were milled, a cheat v3 cam and some ltd with a an x pipe and cherrybombs. I'm going to be getting it tuned some time next week after it gets put back together. Any ideas on what kind of HP tq increase I will see. There is also a spectre cold air intake. Thanks
-50hp... 317s have a combustion chamber of ~71cc. 862s have a combustion chamber of ~61cc... So even if you mill the crap out of them, i don't think you will be down the combustion chamber size of the 862s.... So your CR will drop, the 4.8 has enough issues, dropping the compression is not going to help...
Not only are you talking about BIGGER combustion chambers which will drop compression, power etc.. Theres also the valve shrouding issue as the 317 heads were meant for a 4"+ bore...
GrooveCityZ71
08-31-2015 01:05 PM
