4 x 4 to awd?
Old 04-13-2003 | 05:50 PM
Default Re: 4 x 4 to awd?
Get one without autotrac, because then you wouldnt have to do any special computer tuning because there is no computer functions for the transfer case. Im sure it would be an easier swap. The traction with AWD is definately great, thats the main reason why i got my SS.
Old 04-13-2003 | 09:48 PM
redaddiction's Avatar
ok now i'm confused which one should i get i wish i could know lol well bigtex tell me what you find out throw your diragrams and where do you get those? Also with the floor shifter i would have a big hole in the floor once i took it out but i just need to know which one would be the easier way to go then i can buy that one so come on and lets help marc
Old 04-14-2003 | 12:42 AM
why is the autotrac necessary? i know i needed the rest but why the autotrac? also i know there are a few buttons in the cab and those have to differ from the c3 and a z71 so is there any different wiring situations there?
marc
Old 04-14-2003 | 11:25 AM
ok guys can someone give me a definate answer please <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Old 04-14-2003 | 11:37 AM
it would probably be easier to cover up the hole, than run into some electronics problems, all trucks probably have a stamped spot there already so a cover plate shouldnt be hard to do. If i was gonna do it, id definately get one without autotrac
Old 04-14-2003 | 11:54 AM
Seeing Red Again's Avatar
If it were me I would just take the easy way out and run a RCSB 4x4 with 4.10's from the factory. Swap ya a 6.0, cam, power adder, built bottom end. Keep the tranny and x case in it and engage the 4wd when needed right before a race.
Basically the same route Bix Tex and Parish went. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> IMO, I just don't think a transfer case swap to get full time AWD would be a good bang for the buck modification.
Old 04-14-2003 | 04:04 PM
Neil 6.0's Avatar
From: as far away from Koonerville as humanly possible
It's not good to drive on hard surfaces in 4x4 because the gears in the manual transfer case get in a bind when you make sharp turns, it doesn't like it when the inside & outside wheels are rotating at different speeds. Kind of like making turns in a car with a spool...chirp, hop, clunk, chirp, hop, clunk...
The AWD trucks have clutches inside the transfer case to allow some slippage when turning.
If I win the lotto soon, I'd like to convert my 1500HD to AWD, but I want to do it using the 4L80E. I'd throw in a 427 with a Radix on top and go hunt down parish8. <img border="0" alt="[evil]" title="" src="graemlins/gr_devil.gif" />
Old 04-14-2003 | 08:50 PM
so anyone else have anything to say about this?
marc
Old 04-15-2003 | 12:17 AM
ok well i found one without autotrac and i want to try this and i'm not worried about the best bang for the buck if i was then i would of bough a drag car but do you really think i should go with the no autotrac it does make the most sense as long as the awd transfercase doesn't need anything electronically also why can't you run a 4 x 4 all the time i can't remember why you can't
marc
GMCtrk
18
10-06-2015 03:48 PM
turbo6c3
10-05-2015 06:11 PM
2002_Z28_Six_Speed
10-04-2015 01:34 PM
StrokeTheLS
09-29-2015 08:33 PM
trxmxzx
09-23-2015 09:15 PM
Quick Reply: 4 x 4 to awd?
