400rwhp Lq4?
Old 10-09-2004 | 03:58 PM
kevinc's Avatar
Default 400rwhp Lq4?
Hello,
I'm posting this for a friend who's computer is in for repairs. He has a 67 LeMans that he is researching swapping in an LQ4 into. He is wondering what it would take to obtain 400 RWHP N/A minimum with a stock short block 2002 LQ4 and a 4L60E? He doesn't want to mess with Nitrous or S/C. What cam, heads, converter, injectors, etc would you recommend. Would it be possible with stock heads? He will be running true 2 1/2" dual exhaust from the headers on back. Reasonable lope would be encouraged.
Thanks,
Kevin C
Old 10-11-2004 | 03:08 PM
kevinc's Avatar
Surely someone knows...
Kevin C
Old 10-11-2004 | 03:12 PM
he can run a fairly radical cam actually, the only reason the truck guys don't is becasue the power band goes up and in a truck you need all the low end you ccan get. I would think something around 230 duration on a 112 or 113 lsa. you will probably need atleast a mild port job to get to 400, also do you want 400 to the rw or crank?
Old 10-11-2004 | 03:25 PM
L-EATER's Avatar
11 Second Truck Club
My last 6 liter had an LS6 cam, stage 2 TEA heads and 8psi of boost and it made 404 at the wheels. I wanna see him make a daily driver with that kind of power and no power adder. Not saying it cant be done, but it wont be a friendly motor when its done
Old 10-11-2004 | 04:39 PM
Gordy M's Avatar
Since he has a 3300lb car the easiest way is H/C and a 402/408/422 etc. engine and headers should do the trick. There is no substitution for Cubic Inches to make N/A horsepower.
calsdad
06-14-2023 11:07 PM
02AWDAWSDenali
10-01-2015 05:08 PM
lxcoupe
09-29-2015 09:20 PM
Slammed silverado
09-28-2015 06:14 PM
zraffz
09-08-2015 07:40 PM
Quick Reply: 400rwhp Lq4?
