402/408 hp output
402/408 hp output
what is the typical output of a N/A 402 or 408 stroker motor
with decent sized cam( need suggestions that match heads), free-flowing heads( AFR 225 62cc), all bolt-ons, FAST intake, 90mm tb, lunati rotating assembly
going through a 60e and 10bolt
400rwhp, 450rwhp, 500rwhp, 550rwhp or more
wanting to see if i need a 80e and if not how much spray i can run on the flt level 5 65e
will never see forced induction
will be run NA 90% of the time with spray when i rarely go to the track
5 year bitches!
400rwhp is easy from a 6.0 with a godo setup 6.7 litre expect in the 500s. now you can have alot less if setup wrong. if i dont see between 500 and 550 rwhp ill be pissed
Adkoonerstrator
Why are you asking all these questions now? You have said time and again its going to be like 4 years before you build this motor and by then EVERYTHING is goign to be different.
Have a Merry Christmas.
I would think with a setup like you are talking about 500+FWHP would be cake. Check the dyno section on ls1tech for 408/A4 results. I know they have less drivetrain loss but it should give you an idea of what you could make with a 408. This guy made 470RWHP through an automatic
