402 Radix Idle/missing questions
Hunter, have you done a crank position relearn procedure? That might solve a couple of your issues. I know it helped out on the last stroker motor I worked on.
Have you done anything to raise the idle airflow? Drill out the idle hole in the TB blade or adjust the idle set screw? The stroker is going to need alot more air at idle than your truck was originally set for.
carid
09-10-2015 09:07 AM
