408 cam
Old 03-14-2005, 08:45 PM
BigTex's Avatar
Matt, your lifters should be in VA on Wednesday. Shipped via UPS.
On the cam thing, I'd still lean towards a smaller 408 cam to begin with. Probably something in the upper 220s. Then see if I wanted more cam or not. I'd be looking for a used FMS cam to try out first.
Old 03-14-2005, 09:58 PM
silent1's Avatar
I've run 3 different cams in my 4**ci engines-comp/MTI-244/244 612/612 112 peak hp was at 5800rpms, comp 252/258 612/613 112 peak hp was at 6300rpms, and currently running the LG G5X4 111LS peak hp is at 6500rpms. My truck is my daily driver, other than the lope, it has good street manners.
Old 03-15-2005, 06:22 PM
Need More N2O Mod
mwalls54's Avatar
Originally Posted by mattrem
Matt is the stock motor hurt?
yeah i am have been running around 20-30lbs of oil pressure for quite some time. i have a bad noise when i shut the engine down. and it just keeps getting worse.
Old 03-15-2005, 10:35 PM
11 Second Truck Club
2bseen's Avatar
I had to change my oil pump at 5k miles b/c the oil pressure was very low.
Old 03-16-2005, 05:29 PM
Need More N2O Mod
mwalls54's Avatar
i have replaced oil pump with a high flow and a few lifters and it was good for a few more pounds.
Old 03-16-2005, 06:15 PM
2bseen's Avatar
My new cam is 230/234 595/601 114. I think it will lope alittle.
2500ZL1
01-25-2016 06:30 AM
TXsilverado
11-26-2015 10:54 AM
TXsilverado
09-26-2015 12:48 AM
chevysten
08-13-2015 07:36 PM
steves86ta
07-28-2015 10:21 AM
Quick Reply: 408 cam
