408 is here!!
I had all 8 hitting the windage tray. I used the ARP washers and silver nuts. You need to get those! The washers are extra thick and the nuts are kinda special in their own way.
Well I went and found the nuts I need at Ace, got some washers too to space the windage tray, everything looks good. Had to do some work on the pickup tube to get it to work with the double-roller timing setup, got that taken care of. Got the oil pan and heads on, rear front and valley covers, put the sensors back in and put the motor back in the truck. I think I'm done for tonight.
Two problems I am now facing. I bought 7.4" pushrods, I need 7.3's. I have too much preload now. Won't be getting the truck started this weekend unfortunately. The other problem I already mentioned, is the keyed crank. I either need to find a keyed pulley or have a groove machined into my pulley. I'll have to take care of that next week as well. But - I can get everything else buttoned in the meantime, and just be waiting for a crank pulley and pushrods
Originally Posted by kbracing96
You should be able to put your damper pulley on, just don't use the key.
You already got your versafueler wired up?
Originally Posted by dewmanshu
congrats, it wouldn't be right if there wasn't some issues to work through. LOL
Originally Posted by nightrunner
https://www.performancetrucks.net/fo...ntake+manifold
i found this while searching for something else i just found it humorus how much we change
I decided to go ahead and install the intake manifold tonight too. I'll try to take some pics tomorrow, it's pretty cool lookin
