408 LQ9 Build
TOTM: January 2007
A lot of factors determine how far injectors will go - fuel system type (return vs non-return), vac referenced, pressure, fuel type, and desired AFR. With said, 42's will be fine for your setup.
What is the compression ratio?
Leave the torque management in the transmission and run a cooler to keep it cool and the trans will be much happier.
