408 teardown, pics inside
Old 10-10-2010, 03:44 AM
  #31
10 Second Truck Club
thats sucks atomic,get her fixed soon
Old 10-10-2010, 09:19 AM
  #32
PT's Slowest Truck
budhayes3's Avatar
Originally Posted by Gadgetized
That is normal. Especially on a FI engine where you are running on the rich side. They will look like that after a few minutes of running. The lighter color is just not covered with carbon yet.
I agree...most of the LS engines that I've seen are carbon monsters, even after just a short while of running...
Old 10-10-2010, 09:45 AM
  #33
I have a gauge for that
Atomic's Avatar
Well thats comforting. I have plans for this engine...but it involves different pistons...
I am having a hell of a time trying to get the rod caps off, any suggestions?
Old 10-10-2010, 10:02 AM
  #34
kbracing96's Avatar
Stick a hammer handle on the bottom of the piston and tap in the head of the hammer. That will pull the rod off the cap. That sucks, but looks like an oiling issue to me.
Old 10-10-2010, 11:00 AM
  #35
Tin Foil Hat Wearin' Fool
1slow01Z71's Avatar
The way Ive always done it is loosen the rod bolts half an inch then use a brass punch on the bolts and it will pop the rod loose from the cap then you can back the bolt out the rest of the way and go on with it.
Looks like the main bore wasnt checked and burnt up the thrust bearing. Maybe Ill change my theory after Im not looking at them on my phone.
Old 10-10-2010, 12:06 PM
  #36
Atomic's Avatar
Got them out with a rubber mallet, not too bad. Bottoms of the pistons look brand new, and the rod bearings on the crank dont look bad.
Cylinder walls are good,
The dark spot on the center journal is oil.
Old 10-10-2010, 12:30 PM
  #37
MikeGyver's Avatar
Originally Posted by Atomic
... and the rod bearings on the crank dont look bad.
Compared to what? Even with forced induction, they should look new with your mileage. The damage showing on the rod half of the bearings, mainly the one on the right, doesn't look good. Top half damage indicates detonation. In your case, I'm wondering about oil starvation, with the burnt bearings and damage concentrated on the center main. Weird.
Cylinder walls are good, ...
It's hard to tell, the pics make them look shiny, like cylinders with a zillion miles look. In real life, do they look freshly honed, like they should?
Old 10-10-2010, 01:31 PM
  #38
Atomic's Avatar
The crosshatching is still very evident on the cylinder walls. Im not sure where you are referring to on the crank rod bearings...
Old 10-10-2010, 01:46 PM
  #39
Ph.D. in HUBRIS
custm2500's Avatar
I am not an expert but I am 99% sure you were fat as hell and I bet you washed the bearing out with fuel. The pistons should not look anything like that!!!!!!!!!!! How did you tune this motor? Do you have a A/F ratios of what it was running through the rpm range?
Again I am not an expert but I am confident this was the main issue.
Old 10-10-2010, 02:00 PM
  #40
Atomic's Avatar
11.3 at 2+ lbs of boost, 12.8 from 0 to 2lbs, and 14.45 at stoich.
Quick Reply: 408 teardown, pics inside
