408 on the way, what hp/tq to expect?
#21
WIth a big enough cam, the compression wouldn't be a problem. I'm shooting for 12:1 and plan on a healthy dose of nitrous too. Not sure on how much yet, but anywhere from 100-200 might make it's way there. I think in a 2 stage setup, it would be OK.
#22
Originally Posted by Rhino79
Running a little more compression would be good........but he is ADDICTED to nitrous!
I thought when we were selecting his parts that 10.5:1 would be a good median for all motor and spraying a good shot of nitrous. ATR, the people building his tranny, is the best place around the Little Rock Area IMO. I have used them before without any problems. I don't know exactly what all is going into it but he said that it would have the Torquedrive Hardened input shaft assy. and all the hard parts like upgraded sprag, 5 pinion planetaries, good clutches with Kolene steels, I don't know which band he was planning on using, but he named off some other parts I just cant remember now. Hauler, you DEFINETLY better get a progressive controller to help the 60e live as long a life as possible!
![Chug! Chug! Chug!](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_chug.gif)
#25
Yah I like my little progressive controller briles!
Not to hate or nothin but I wouldnt do much **** talkin on a serious note to the cobra, if his ***** ever drop to race ya it would be a close. The L wont touch you on motor. I beat him by half a truck not spraying threw my shifts. 100 shot!
But even with your 1 wheel peel and the slicks you need to come get aholt of him with the 4.8l before the 408 goes in.
#26
9 Second Club
Racing on the 4.8 is done, they'll get what's coming to them with the 408. What does the cobra run? I'm pretty sure that the Hauler could easily handle the Lightning even with one wheel peel but there is no reason to risk breaking something this close to time for the swap. I know that Deron's Cobra is like the hometown hero, but who has he beat or run? The T/A beat him on motor if I remeber correctly so he will definetly need more than that. The Hauler's 408 is gonna be a bit stronger and quicker on just motor than he is with spray right now, then add a 200 shot to that. With spray he probably runs 12.50-12.70's hooking good so with a 408 + 200 shot the cobra is gonna have it's hands full.
#29
Tin Foil Hat Wearin' Fool
You will find that cam to be WAAAYYYY too small. Rhino I told you that when you sent me a PM long ago about cam choice. In my HEAVY as truck compared to his along with a t-case and everything else to spin, even in 4hi on DRY concrete I would spin all four for 10-15 feet on MOTOR how do you think his truck is going to do with more useable power down low and ALOT less weight and in 2wd I dont care if has a 4-link and 30" slicks it is going to be fun launching on the street and that is the understatement of the century.
#30
9 Second Club
![The Jester](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_jest.gif)
![The Judge](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_judge.gif)
