The 418 rotating assembly is FINALLY here(pics)
#32
Originally Posted by fogle04
i believe a jerico is what they use in nascar. i got a booklet on the covers. they are a little pricey. they have tall and short ones. i think the cheapest ones where around 300.
#35
Originally Posted by black4x4
get that bitch together and see if the 60e will hold it.
![Rolleyes](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/rolleyes.gif)
A nicely built 80e is in my trucks near future after I get some personal stuff lined out and recover from the hit of the 418
#38
Originally Posted by XLR8NSS
Looking good man. Is it together yet?
![Grin](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_grin.gif)
![Tongue](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_tongue.gif)
![Bang Head](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_banghead.gif)
Still waitin on the cam, head bolts, main studs, head gaskets, heads, valve cover spacers, my headers back from the ceramic coater, and jesel shaft mounted roller rockers
![Sad](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_sad.gif)
#39
Hell no. Still waitin ARP main studs so the machine shop can bore the block and and all their stuff.![Bang Head](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_banghead.gif)
Still waitin on the cam, head bolts, main studs, head gaskets, heads, valve cover spacers, my headers back from the ceramic coater, and jesel shaft mounted roller rockers![Sad](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_sad.gif)
Did you go with the adjustable rockers or the other ones you just bolt down? Im trying decide Im just affard Ill buy the one you just bolt down and have to end buying different pushrods.
![Chug! Chug! Chug!](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_chug.gif)
#40
Originally Posted by Yellowsierra
Did you go with the adjustable rockers or the other ones you just bolt down? Im trying decide Im just affard Ill buy the one you just bolt down and have to end buying different pushrods. ![Chug! Chug! Chug!](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_chug.gif)
