The 418 rotating assembly is FINALLY here(pics)
Old 11-30-2005, 08:54 PM
  #31
Fogle07's Avatar
i believe a jerico is what they use in nascar. i got a booklet on the covers. they are a little pricey. they have tall and short ones. i think the cheapest ones where around 300.
Old 11-30-2005, 09:07 PM
  #32
Tin Foil Hat Wearin' Fool
1slow01Z71's Avatar
Screw that Ill buy the spacers and just clean my stockers up a little or get you to paint them.
Old 12-01-2005, 08:00 AM
  #33
black4x4's Avatar
get that bitch together and see if the 60e will hold it.
Old 12-01-2005, 09:32 AM
  #34
Injected1's Avatar
slow01z71...if you dont mind my asking...where you order that from? I got a 6.0 looking for some more inches in the garage.
Old 12-01-2005, 05:08 PM
  #35
1slow01Z71's Avatar
Its going to hold up I promise
A nicely built 80e is in my trucks near future after I get some personal stuff lined out and recover from the hit of the 418
  #36
1slow01Z71's Avatar
PM sent
Old 12-01-2005, 05:53 PM
  #37
Adkoonerstrator
XLR8NSS's Avatar
Looking good man. Is it together yet?
Old 12-01-2005, 06:23 PM
  #38
1slow01Z71's Avatar
Hell no. Still waitin ARP main studs so the machine shop can bore the block and and all their stuff.
Still waitin on the cam, head bolts, main studs, head gaskets, heads, valve cover spacers, my headers back from the ceramic coater, and jesel shaft mounted roller rockers
Old 12-01-2005, 06:39 PM
  #39
Yellowsierra's Avatar
Did you go with the adjustable rockers or the other ones you just bolt down? Im trying decide Im just affard Ill buy the one you just bolt down and have to end buying different pushrods.
Old 12-01-2005, 06:43 PM
  #40
1slow01Z71's Avatar
BOlt down. They arent one solid shaft all the way across. It is two rockers per shaft so you can just shim them to the right valve lash. There will be pics and Ill post up how I adjusted them once I get to that point which right now looks a long ways off
Quick Reply: The 418 rotating assembly is FINALLY here(pics)
