427 + TVS2300 1500 Silverado, bad exhaust?
Old 10-01-2011 | 06:37 PM
ayousef's Avatar
Default 427 + TVS2300 1500 Silverado, bad exhaust?
well the car is an 2010 Silverado 1500 with a 427, TVS2300 at 8PSI and the exhaust is
SLP high-flow catted dual 2.5 to single 3inch split to dual 2.5" to the back.
Will run true dual 3 inch exhaust to the back, and take the cats off. Ill also swap out the throttle body to a ported Z06 throttle.
Any ideas on how much power I should gain? Truck is rated at 700bhp from the builder.
Old 10-01-2011 | 06:46 PM
supersub's Avatar
what style 2300 are you running, pulley size, compresion ratio, type of heads, size of the headers(primaries). and the throttle body should be bigger, porting a 90 will show very little in performance vs money spent on the porting, i would suggest the 102mm to start.
Old 10-01-2011 | 06:58 PM
ayousef's Avatar
just bought the car brand new a few days ago, so I probably cant answer even half of those questions. I need to speak to the engine builder after tomorrow to find out more.
Primaries (longtubes) look like **** im guessing 1 3/4. Would love to have 2" primaries in there, tell me if you know anyone who does them for a 1500 without any clearance issues?
compression ratio is 10.3, 8psi (pulley size unknown), heads unknown.
Throttle body is a stock 5.3 liter throttle whatever that size turns out to be. I would love to go with a 102, but im worried about tuning the drivability. I was reading a little about those throttles for a Z06, seems most of the problems went away by merely adjusting the throttle body area scalar in the tune.
I know I probably didnt help much in this reply, but im figuring it out.
Old 10-01-2011 | 07:05 PM
supersub's Avatar
I am assuming you are running the front inlet front drive supercharger!?! that would explain the lower boost #'s, ARH makes a nice 1 7/8 version, thats what i have., the 102 will be a huge benifit. tuning it well thats not my dept. sorry i pay someone to tune my set-up. Not enough personal hardrive space to tune myself, so i just stick to building.
skeet's Avatar
supersub is correct, that setup will choke that 427 tvs2300 to hell and back, open the exhaust and let her flow, the inlet air needs to be BIGGER .
Old 10-01-2011 | 07:12 PM
ayousef's Avatar
Thanks buddy, the car was tuned by a professional tuner, but I can tune myself as well. The 102 is a little harder to tune, but I could give that a try, should work well with the 4" inlet pipe, and yes thats a front drive TVS.
Its pretty fast even with it being choked, im surprized those guys can build such a nice truck and miss out on a lot of things. The truck also has 4.10's in the back, unfortunately stock drivetrain parts which is why I dont want to pulley down.
Ill open up the exhaust and opt for a bigger throttle body for starters, plus oil coolers and a few things.
Old 10-01-2011 | 07:17 PM
supersub's Avatar
I would recomend the DRx x-link for the plug n play harness adapter,and TPIS for their 102mm throttle body and their matching 102mm flange i helped design. minor porting of your inlet and bolt n go.
Ketis
07-23-2015 01:37 PM
FlowmasterMufflers
07-17-2015 04:26 PM
ferrellrooster
07-13-2015 10:53 AM
Mark_k
07-08-2015 11:44 PM
cwylie
07-07-2015 12:42 PM
