42lb. injectors, will they fit?
Old 09-08-2004, 10:30 PM
11 Second Club
Texas Terminator's Avatar
Originally Posted by BenKey
If you are raising the rail, and the crossover is connecting the two rails, thus raising it also, why is it necessary to bend the crossover? Is this just to get the engine covers on? Just curious.
because when you raise them, they get farther apart. both in width and front to back. think about it, the injectors aren't in there straight up and down and the new ones are longer. you'll see. it's not that big of a deal.
Old 09-09-2004, 04:59 AM
Where do the spacers go. Does someone have pics of the spacers? 1/8" pipe and 5/8" long approximately?
Old 09-09-2004, 06:26 AM
I only asked that, because I didn't need to do it. I put spacers in and everything still fit like a glove. I didn't have any trouble not manipulating the rails. Nothing was forced, it just popped right back in.
Old 09-09-2004, 06:27 AM
If you look on your fuel rail, you'll see 4 bolts, I believe, holding it down. Just remove the 4 bolts and place the spacers underneath the tab that the bolt goes through.
Old 09-09-2004, 07:12 AM
Now I think I understand. They go around the bolts to raise the whole assembly up. Then will I have to get longer bolts to?
Old 09-09-2004, 07:27 AM
CoonToot's Avatar
Send a PM to XLR8NSS...he has a link to a step-by-step install. I have the link at home - I will post it up tonight.
Old 09-09-2004, 07:42 AM
Yes. The whole process from start to finish takes maybe 5min once you have the spacers and new bolts. Changing out electrical connections will take considerably longer.
Old 09-09-2004, 10:07 AM
Thanks. Just sent a PM to XLR8NSS about the link.
Old 09-09-2004, 01:57 PM
Adkoonerstrator
XLR8NSS's Avatar
Here is the link.
http://hauln.net/LS1Tech/truck/fuel_injector/index.html
Old 09-09-2004, 02:23 PM
Thanks for the help. That site helped a lot.
GXPJAY
02-13-2022 08:15 AM
Aboss
08-11-2015 09:05 AM
Ammadien
07-22-2015 08:50 PM
maxspeed05V
07-19-2015 07:08 PM
Quick Reply: 42lb. injectors, will they fit?
