4L60e in 2003 Denali 6.0
I recently changed the flywheel and am putting in a reman 4l60e. The torque converter bolts do not line up.
Parts supplier gave me pioneer FRA452 as the correct flywheel for 2003 Denali 6.0 awd
Used spacer and longer bolts as well because it hit the oil pan without it.
I installed the 4l60E and torque converter holes are almost 1/4'" in from holes on flexplate.
from what I am researching is to elongate the holes, Is the flexplate wrong or the converter?
Does anyone have the part number to a flexplate that will bolt to this converter?
truck had a 60 in it and not an 80 which would cause this problem from what I read,
Thank you for any help.
100% Redneck
dirt track racer 81
10-28-2006 02:42 AM
