4l80e conversion underway
Ok, it is finished and I have put about 50 miles on it so far. I haven't been able to get on it yet-I made up a real quick edit file and flashed it into the PCM of my '02 then switched 'puters just so I could get it going. I have the wrong timing tables and it it detonating at any thing resembling heavy throttle.
The actual swap was so easy and simple that I don't know why I didn't do it sooner. The crossmember worked without modification, as did the driveshaft except for changing the slip yoke. The only things that had to be modified were the wiring, the rearward most cooler line, and the shifter linkage. I am going to reprogram the timing in the morning then I will be able to take it out and beat on it to see if it will get a 2nd gear scratch lol.
Originally Posted by nice_n_lo_silverado
what are the advantages to the 80 swap, other than its a beefed up tranny?
