4L80E Conversions & Truck Cams Now Available
#51
Location: Formerly Hayden, AL . . . Now Attleboro Falls, MA
On the 4WD conversion, I'm assuming that you will offer the 4WD crossmember and driveshafts once you get them built? Also, on the T-case input gear, how much disassembly of the tranfer case is required, i.e., is it just a relatively quick bolt-on adapter, or will we need to take the case most of the way apart?
Thanks,
Kipp
Thanks,
Kipp
#53
Originally Posted by Speed Engineering
Manhole Cover
Yep, I am going to put it up on the site right now. The crossmember will have to be fabed up on the T-Case, shorter rear driveline, and a longer front driveline. Other then that i think everything else is a swap i beleive.
Sean (559)348-0200
Sean (559)348-0200
#54
As far as the capability of the 1500 transfer case, I believe the Autotrac case is the NV 246, correct? Is so, then New Venture Gear's site lists its max torque as 2281 ft-lbs. For comparison, I'm pretty sure the 2500s get one of the following cases: NV 261 (2564 ft-lbs.), NV 261 HD (5430 ft-lbs.) or the NV 263 HD (5430 ft-lbs.). Anyone know which case the 2500s actually have?
These are max. capacity torque ratings, according to the web site. I'm assuming that means that there is some calculation involved in getting to input engine torque. . . Probably have to account for transmission gearing, torque converter efficiency, and torque lost due to transmission . . . also bet that the max. capacity number is based on the vehicle being loaded to its maximum gross vehicle weight.
Anyone have any idea on how to back out the max. input engine torque?
#55
Thanks,
Kipp
Thanks,
Kipp
ecthelion has a good point. Now that we can do the swap how much can the T-Case hold before needing to upgrade to the heavy duty one.
Sean
Suburban2500
07-19-2015 04:50 PM
mrgrim
07-08-2015 08:12 AM
zaathur151
07-06-2015 10:57 PM
