4l80e tranny
single digit dreamer
Originally Posted by fast2001
the stock 4l80e tranny will handle a 550 hp 409 stroker with no problems
Parish8 will be running one with his 408 turbo setup pretty soon all he's running is a shift kit and a converter.I bet it holds up and Parish is not known for being easy on transmissions.
this is for a 4wd, i plan on adding some spacific 2wd stuff sometime that whitt has put together. http://www.neufamily.org/4l80e/4l80swap.html
parish8,
when you decided to use a 4l80e tranny, did you consider the turbo 400 instead. I talked to a guy on the web and he suggested the turbo 400. What are your comments on it.
