4L80e/TransGo Shift Kit/Line Pressure
Old 03-31-2005, 11:05 AM
what a rush!
moregrip's Avatar
Default 4L80e/TransGo Shift Kit/Line Pressure
what change to line pressure did you perform when you put the shift kit in your tranny?
Old 03-31-2005, 02:50 PM
what a rush!
moregrip's Avatar
I know there are folks around here that can answer this,
p-l-e-a-s-e
Old 03-31-2005, 03:36 PM
Eye-P's Avatar
the kit is designed to use the stock trans settings.
Old 03-31-2005, 04:34 PM
what a rush!
moregrip's Avatar
thanks, I was also wondering what guys like parish might have done as well.
Old 03-31-2005, 04:46 PM
FLP did mine ,so I don't know.
Old 03-31-2005, 04:47 PM
what a rush!
moregrip's Avatar
hehehe, damn
Old 03-31-2005, 05:52 PM
FILE's Avatar
TTT... I'd like to know this too.
Old 03-31-2005, 07:20 PM
13 Second Truck Club
Location: Pueblo de Nuestra Señora la Reina de los Ángeles de la Porciúncula
I'm not 100% positive but you don't have to change the line pressure settings if you get a shift kit. That's the point of the shift kit...to firm up the shifts mechanically instead of electronically, which is what you're doing when you raise the line pressure. Please correct me if I'm wrong.
Old 03-31-2005, 07:22 PM
what a rush!
moregrip's Avatar
not sure, I hope thats the case, because then it will be a no brainer, but I am no longer stock on these values.
Old 03-31-2005, 07:37 PM
Also, if you get a shift kit TM will be ALOT more noticeable, annoying even.
Quick Reply: 4L80e/TransGo Shift Kit/Line Pressure
