4l80e upgrades, thoughts?
Old 11-24-2004, 11:56 PM
what a rush!
moregrip's Avatar
just in case some didn't follow
4l80e = MT1
4l85e = MN8
Old 02-21-2005, 11:15 PM
what a rush!
moregrip's Avatar
Originally Posted by James B.
The TransGo Shift Kit is awesome. It does everything it promises and does it well. Installation on a 4L80-E involves quite a few holes drilled in the valve body and separator, unlike the 4L60-E kit which requires drilling only the plate. As long as you have to take it down that far it's also a good idea to replace the separator plate with the TransGo hardened one and make the shift kit modifications to that one. The checkballs in 4L80-Es are known to wear out the stock plate, eventually a ball can become lodged in a hole. There are a few upgrades in the kit that are pump modifications or internal upgrades. These can only be done if the transmission is torn down for rebuild, so they can be skipped.
There is a lot of talk on here about switching out the line pressure boost solenoid with a vacuum modulated one. Unless you are running a turbo charger this is not needed, here's why: With a naturally aspirated or supercharged engine the amount of torque the engine is putting out is fairly consistent for a given rpm and throttle position. Because a turbo spools independently of engine rpm there can be a variable range of torque output for a given throttle position and engine RPM. This is about the only setup a vacuum modulated boost valve might be more effective than a properly programmed stock electronic one.
While you are at it, I like this:
Part number 70295 GM 4L80E (adds 3 qt.)
http://www.bmracing.com/products/tra.../deepPans.html
Is this the seperator plate you were talking about?
http://www.transmissionpartsusa.com/...-004681301.htm
Old 02-21-2005, 11:18 PM
James B.'s Avatar
Why yes... yes it is! Too bad there's no picture, it's one sexy bish
Old 02-21-2005, 11:24 PM
what a rush!
moregrip's Avatar
I really need to get this done first or second week in March, since your in SoCal, I may need an emergency #
Old 02-21-2005, 11:30 PM
James B.'s Avatar
I...since your in SoCal, I may need an emergency #
I'm easy to get ahold of, just send me E-Mail. jbertok (at) jaguar.net or jamesb (at) downsenergy.com
Also have ICQ, crappiest software of all time - 1438691
Old 02-21-2005, 11:41 PM
what a rush!
moregrip's Avatar
thanks, I might need it.......
Old 02-22-2005, 11:35 AM
Faze2183's Avatar
http://stores.ebay.com/Oregon-Perfor...QQftidZ2QQtZkm
Old 02-22-2005, 11:36 AM
Faze2183's Avatar
nuff said on that post heh, talk to brian good guy wont let ya down, fast shiping, EBay user: Keyguy2002
Old 02-22-2005, 11:40 AM
what a rush!
moregrip's Avatar
great link, thanks!
do you know this place? reputable?
Old 02-22-2005, 11:51 AM
what a rush!
moregrip's Avatar
didn't see this one
thanks
Quick Reply: 4l80e upgrades, thoughts?
