4WD launching/weight/tranny swap questions
Old 01-16-2005, 07:48 PM
  #31
dragonman0325's Avatar
Yeah Parish I was thinking a pretty high stall would help his situation alot. The 2 step idea is probably the ticket. Man I'd like to see that truck launch then. Parish do you have any godo videos of your truck launching down the quarter?
Old 01-16-2005, 08:09 PM
  #32
single digit dreamer
parish8's Avatar
i have been thru exactly what he is going thru.
first it was bucking, then let down the tortion bars and that helped. eventualy you get enough power that it lifts the front up anyways and bucks again. that leads me to the front suspension limiters. my truck now just lifts a little and then peals out prety smoothly. here is a vid. https://ls1tech.com/forums/showthrea...ghlight=launch
Old 01-16-2005, 08:13 PM
  #33
WOW! I'm still smiling from that! Man that turbo spooled up makes the baddest sound. Looked like a really controlled launch too. I see the brakes are letting you down a little too.
Old 01-16-2005, 08:23 PM
  #34
parish8's Avatar
yeah, it is spining but it is smooth. i think smooth is the key here. i can control the brake boost prety easy and still get a hard launch. with the 6.0 i had the same problem as f8l, to get a decent launch i had to brake boost hard and then it would just pull right off the line no matter what. i found it helped to stage last and then go right into the brake boost. that brought the boost up just in time to launch. if i staged first i had to much time to brake boost and ended up rolling off the line or having to let back off
Old 01-16-2005, 09:14 PM
  #35
KeukaZ71's Avatar
How well does the 4x4 system handle all that power? Is there somethign that's gonna wear out or grenade under all that power? Whats the weak link? Parish have you blown anything up or is your 4wd system beefed up?
i don't have much power, but i have worn out a few things:
- u joints
- transfer case driveshaft seals
Old 01-16-2005, 09:28 PM
  #36
F8L Z71's Avatar
I am pretty sure I am closer to 3k RPM when boosting but I have so much other stuff to concentrate on that I honestly havn't looked.
My new combo will probably be much easier to launch on, well build boost on anyway.
370ci 6.0L
GT67 with .96 A/R or GT70
4l80E with new converter (3000-3200most likely)
I am most likely gonna stick my old wet kit on the truck too and see if I can't sneak into the 10s.
I know with the nitrous I am going to be in the same boat Jim is now. I'll have to do the limiters (thank god you figured that out for us) and some better tires.
Old 01-16-2005, 10:40 PM
  #37
James B.'s Avatar
Have any of you guys with turbo trucks tried switching out the crappy vacuum-assist brake booster for a hydraulic one? Awesome upgrade to the brakes. Even with huge boost or a cam that barely pulls vacuum at idle the brakes work twice as well as the stock system, and the pedal is always much more firm.
http://www.hydroboost.com/index.html
Here's a picture of it on the Tahoe:
http://james.jaguar.net/pics/Hydroboost-done.jpg
Old 01-16-2005, 10:51 PM
  #38
F8L Z71's Avatar
I had never heard of doing it. I'll defiantely look into that. My brkaes have sucked sine the day I bought it.
Thanks for the tip James! So what about those vids of your wheelie monster?
Old 01-16-2005, 11:04 PM
  #39
what a rush!
moregrip's Avatar
I thought I asked for vids a few back
James B, ahh, Vids please
Old 01-16-2005, 11:05 PM
  #40
what a rush!
moregrip's Avatar
I guess I have a different system, cause my brakes are not vaccum assisted
Quick Reply: 4WD launching/weight/tranny swap questions
