5.3 to 6.0 swap, easy or not?
Where can you get a LQ4 at for that price ?
LQ4 is the 6.0 345 hp engine correct ?
I would think that the LS6 405 hp would still have more power with about a 125 shot ?
You think they can get 55 hp out of those patroit heads ?
first, dont believe those factory numbers, they prety much just make up those numbers, it is all marketing.
A heads and cam lq4 would kill a stock ls6. call me crazy but i think a cam only lq4 would be quicker than a stock ls6.
here are a few of my dyno numbers with an lq4, all with pump gas and cat back pulled(or cut out). thru a 4l80e and tcase and 31" tall tires.
322rwhp with a cam only lq4 thru a power robbing driveline seems prety good to me. figureing a 20% driveline loss and that would be over 400fwhp.
the 6.0 heads are the same casting as the ls6 heads other than chamber size, then add in a few cubes but drop some compresion and i think they would be real close to the same numbers.
how much money do you have to spend? for $5000 you could build one heck of a motor, forget about the $5400 ls6
