5.3 to 6.2 engine swap
Old 02-16-2016, 07:41 PM
Registered User
MXDAD140's Avatar
Default 5.3 to 6.2 engine swap 2001
I have a 2001 Chevrolet 1/2 ton truck with a 5.3. I have read some of the swap over answers but none specific to my year model truck. Could anyone tell me what exactly it will take to make this conversion work? I would like to use my transmission out of the 5.3 also.
Old 02-17-2016, 03:12 AM
Banned
2WDinSnow's Avatar
Buy a lq4, bore it to 4.065, buy ls3/l92 pistons put it back together and swap it in. No computer boxes to mess with and if done right should cost less than $1500 for a freshly rebuilt iron 6.2
Old 02-17-2016, 12:19 PM
Registered User
MXDAD140's Avatar
Thanks for the info. I think this is the route I am going to go.
Old 02-17-2016, 01:00 PM
Formerly ScreamingL
George C....'s Avatar
Thats not smart advice especially since not every 6.0 block can safely go 4.065 since some have been known to split a wall at 4.030
Old 02-17-2016, 01:12 PM
Banned
2WDinSnow's Avatar
so far I've had 3 different blocks sonic checked and all of them had more than enough clearance 2 LQ4's 1 LY6.
I have not seen a 6.0 split a wall and my builder has some at .80 over I think the odds of it not being able to go is slim to none
Old 02-17-2016, 02:23 PM
Formerly ScreamingL
theres been spilt 6.0s since the beginning one of the founders on this site for performance split a 6.0 block, if you dig deep enough youll see plenty
hell flaco back in his 414 days split quite a few
Ive had a 6.0 in my possession with a split wall
Old 03-05-2016, 12:57 PM
Registered User
MXDAD140's Avatar
Ok. I finally have my 6.0. It's a LQ4 from a 2000 3/4 ton truck. It has cast iron heads on it. I won't be punching it to a 6.2 afteral but will be boring if it needs it.My question is would any of you change the heads? and if so to what? I will be using the GM LS Hot cam kit p/n 12480033.Also what type pistons would you recommend? I will be using this as a daily driver. Just want the extra power for a little grudge racing time to time.
Old 03-05-2016, 01:05 PM
Wolftrk99's Avatar
If you have an iron headed 6.0, it has the funky oddball crank designed for the 4l80, what trans does your truck currently have??
Old 03-05-2016, 01:08 PM
Registered User
MXDAD140's Avatar
My truck is a 2001 1500 with a 5.3 reg cab swb. Nothing has been changed on it.
Old 03-05-2016, 01:17 PM
Wolftrk99's Avatar
You should have a 4l60, i dont know that the crank will allow a 4l60 to bolt to it.....
Quick Reply: 5.3 to 6.2 engine swap
