5.3 to 6.2 engine swap
Old 03-05-2016, 01:48 PM
Registered User
MXDAD140's Avatar
Originally Posted by Wolftrk99
You should have a 4l60, i dont know that the crank will allow a 4l60 to bolt to it.....
When I asked a while back no one said anything about this. I hope that it will bolt up since I've already purchased the engine.
Old 03-05-2016, 02:02 PM
Formerly ScreamingL
George C....'s Avatar
Scrap that motor
Old 03-05-2016, 02:07 PM
Registered User
MXDAD140's Avatar
Originally Posted by George C....
Scrap that motor
Curious of why you would scrap this engine?
Old 03-05-2016, 02:10 PM
Formerly ScreamingL
Its a weak motor from factory, crank is a bastard, heads are garbage
Onky good thing from motor is the actual block
These motors sell for 200 complete since they are not desired
Old 03-05-2016, 03:03 PM
Registered User
2shawnz's Avatar
Anyone know what all is needed to do a LS swap into a Colorado currently with a 3.5? 4wheel drive if that matters.
Old 03-06-2016, 09:58 AM
Registered User
MXDAD140's Avatar
Got ya. I thinks I've found some 243 heads. Working on finding another crank also.
Old 03-06-2016, 10:25 AM
Formerly ScreamingL
Change the rods and pistons while youre at it
Old 03-06-2016, 11:19 AM
Wolftrk99's Avatar
Wiring harness, trans bellhousing(if 4l60e), trailblazer 5.3/6.0 oil pan(iirc colorados have same setup with the axle going through the oil pan) accessory drive, whole bunch of stuff.... probably less expensive to trade it in on a colorado with a 5.3 or a silverado....
MINK
19
07-08-2020 04:08 PM
FlowmasterMufflers
11-26-2016 10:13 PM
L$X$10
05-17-2016 04:24 PM
Antsilver
48
02-03-2016 03:16 PM
Turbo6.0
01-27-2016 10:33 PM
Quick Reply: 5.3 to 6.2 engine swap
