5.3 buildup Questions >400hp
Thanks again guys, the input is great and appreciated.
another question, what about a LS1 intake, does it bolt up to a 5.3? Also is there any advantage to a LS1 intake over the stock 5.3 intake in either N/A or turbo?
Pete
Pete
Pete
Pete
Down side to the LS1/6 intakes is that you will need a LS1 water pump to go along with it. The truck intake sits up much higher. Also car intakes don't usually have the EGR port open. Those with 99-01 trucks would need to block off the EGR and remove from programming.
grantpo
07-15-2015 12:21 PM
