5.3 FI. Blower or Turbo?
And what are the limits are the factory internals on this 5.3?
and what are the limits for a stock 6l80e? Can't seem to get a consistant answer on this one. Some say they're bulletproof, and the 4l60's are the ones that need to be built. And some say at 500whp, the 6l80 should start getting some upgrades.
He has a 370, so a 6.1?
A stock 5.3 can make 1000whp+, just depends on long you want it to last.
Through a bone stock exhaust, with an LS9 cam my 5.3 made 477 with 12lbs. My heads flow worse than yours, and I had the NBS intake at the time.
Your truck/your gen motor with 12lbs will be healthy into the 500s.
500s should be no problem for daily reliability on any gen 5.3, IMO.
I think the 370 is on his new build if I'm reading his sig correctly. He referenced the 118.5 trap that's in the first line of his sig. could be wrong though.
And thanks for the info. That's what I was looking for. What blower/turbo were you running?
Any idea what the 6l80e could handle with out any upgrades?
mikealicious2k5 (04-22-2017)
Didn't think of the heavier tires putting strain on it. Good call. Will be mounting 33" LT tires on it this summer, instead of the 31" P metrics I have on there now. 16lbs heavier per tire.
I leaning towards the 1900 just for the simplicity. Then just add cam and smaller pulley down the road.
