5.3 Lm7 To 6.0
Old 10-18-2007, 12:03 PM
1cfar's Avatar
Default 5.3 Lm7 To 6.0
I have the piston slap problem and trying to figure the best way to repair-
new pistons and bore to 5.7
Will a 6.0 engine fit in a 5.3-using the 5.3 accessories and wiring?
or can i just use the block and put my upper end on it.
Thanks
Old 10-18-2007, 11:39 PM
nonnieselman's Avatar
I just dropped a LQ4 in my truck... swapped out the LM7 for it..
Mine truck is a 2000... and the LQ4 was a 2004.... only thing i had to do was
Swap out the flexplate cause the one on the 6L had a 4L80E and i have a 4L60E...
And the oil pressure sensor...
everything else is the same...
Wiring and everything is the same...
Have fun!!!
Old 10-19-2007, 08:44 PM
1cfar's Avatar
thanks-I'll check into it
lxcoupe
08-26-2015 07:24 PM
Abuckeye
08-19-2015 06:11 PM
JordanH
08-08-2015 07:59 PM
lxcoupe
07-30-2015 02:42 PM
steves86ta
07-28-2015 10:21 AM
Quick Reply: 5.3 Lm7 To 6.0
