5.3 oil pressure drop after cam swap
Old 06-12-2012, 06:06 PM
probably knicked a cam bearing or 2 installing it.
Old 06-12-2012, 08:39 PM
Custm2500's Rude Friend
1FastBrick's Avatar
Why would put an LQ9 cam In an LM7??? There is very little difference in the 2 cams.
5-30 Is to thin for forced induction applications.
If you are using regular Oil, 5k miles is way to long between oil changes especially with forced induction.
Old 06-13-2012, 12:23 PM
1SloLQ9's Avatar
I put the lq9 cam in because it was basically free and only took a few hours to install, I know there is not much to gain, I figured with forced induction it would help in the higher end of the rpm band since that is where these cams make there power, I was very careful removing and installing cam I used no force to remove cam at all, slid out very slowly and carefully and reinstalled the same way. Also the supercharger has only been on the last few weeks of which I maybe put 300 miles on it. I'm planning on running 10w30 synthetic when i change it. I will keep this post updated as for oil pressure once i change oil this week.
Old 06-13-2012, 03:24 PM
1FastBrick's Avatar
FWIW stock cam specs
https://www.performancetrucks.net/fo.../?ref=esp-link
5.3 LM7
190/191 int/exh @ 0.05" duration
0.466" / 0.457" int/exh lift
114 LSA
6.0 LQ9
207/196 int/exh @ 0.05" duration
0.479" / 0.467" int/exh lift
116 LSA
Old 06-13-2012, 03:26 PM
1FastBrick's Avatar
So the oil pressure swap started after the cam swap, but before the supercharger???
Curious to see if the oil change to 10-30 helps
Old 06-13-2012, 03:49 PM
1SloLQ9's Avatar
Yes oil pressure drop occured after cam swap before charger. I replaced the cam retainer plate after first noticing it. then figured its not dropping any lower then 20-25 at hot idle, pulls about 30-35 going down highway. if i rev it up in neutral it will hit 60lb by about 4krpm. So I will try the oil change and see if it does it. Its also been quite a bit warmer out since we did the cam. it was around 50-60 then its now in the 80's pretty regularely.
Old 06-13-2012, 04:04 PM
13 Second Truck Club
LS1FREEK's Avatar
5.3 LM7
114 LSA
6.0 LQ9
116 LSA
Trucks and SUV with Vortec engine LR4 and LM7
99 12560966 191/190 .457/.466 115.5
00-04 12560967 191/190 .457/.466 114
the 03-04 LM7 used the 12560967 camshaft
LQ4
99-00 12560967 191/190 .457/.466 114
01-04 LQ4 cam is same as Camaro, Corvette LS and LQ9 cam
LQ9 02-03 12561721 196/207 .467/.470 116
You've got the intake and exhaust mixed up on the LQ9 cam.
BTW, 17 degrees of increased exhaust duration seems a bit significant to me, I know an LQ4 cam swap into a 99 is a significant gain in performance, especially low end TQ, I've done it
Old 10-24-2012, 10:28 PM
TexasGMC08's Avatar
I had this same issue! Come to find out I had to change the valley cover! And it fixed the oil pressure and its back to normal..
Old 10-25-2012, 11:25 AM
gagliano7's Avatar
It could be the 6.0 cam bearing clearances with your 5.3 cam bearings..It could have wore differently in his truck compared to yours.
Noah Burns
09-07-2015 05:50 PM
Ferocity02
07-17-2015 07:05 PM
Mossyoakglock
07-17-2015 08:30 AM
06 4.8
07-15-2015 07:17 PM
Aboss
07-09-2015 10:28 AM
Quick Reply: 5.3 oil pressure drop after cam swap
