5.3 top rpm
Right now my shift point is 5800 rpm's on my 5.3.I was wondering what I would need to change to run it up to 6000?I was thinking valve springs and push rods or is all this a waste of time with a stock cam?Does this cam fall off after 5800[anyone with dyno runs]?
I shift at almost 6100 (sometimes 6050 or 6095 or 6105) It doesn't really make much power that high stock but it DOES put your 2nd gear shift at a higher RPM. Thats why I do it, seems to work
I was shifting mine at 7k.
It did burn up a wrist pin though. It took a while for it to happen. The bottom end will hold just fine with just some ARP bolts.
I have some if anyone would like them. They are the good ones, ARP2k rod bolts. PM me so we on't jack the thread.
![Grin](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_grin.gif)
Originally Posted by truckmann
The stock internals can handle more than 6000, but the stock cam and intake aren't gonna do much for you above there.
![Stupid](https://www.performancetrucks.net/forums/images/smilies2/stupid.gif)
You can rev up to 6400 safely but i personally wouldnt do it. Rod end bolts begin to fail around 6500 RPM iirc.
