5.3 vs 243 Heads...Confusion
Old 06-01-2007, 06:56 AM
nighthawk08's Avatar
does anyone know the piston to deck height in these engines?
Old 06-01-2007, 07:03 AM
Originally Posted by pbraxton
and i was curious why the new 5.3's are making better numbers with those heads.
the new 5.3's have flat top pistons and 9.9:1 compression, ls6 based heads, 90 mm TB/intake manifold and a slightly larger cam. these are the factors producing more power.
Old 06-01-2007, 07:06 AM
ChevyThunder17's Avatar
I *think* the piston protrudes .008" out of the deck, similar to the 5.7's. I'm not sure though.
Old 06-01-2007, 07:12 AM
tdrumm's Avatar
Bore 3.78 gasket bore 3.91
Stroke 3.62
Chamber Vol 58.8
Compression Height -0.008
Piston dish Vol 7
Gasket thickness 0.045
Displacement volume -1.471179387
Gasket Volume 8.854378301
Swept Volume 665.7086726
Compression Volume 73.18319891
Compression Ratio 10.09646862
Old 06-01-2007, 07:13 AM
tdrumm's Avatar
Yep, I measured mine with a bridge when I had the heads off.
Old 06-01-2007, 08:55 AM
Stroke 3.62
Chamber Vol 58.8
Piston dish Vol 7
Yep, I did +.008 for the deck height, didn't click the negative. Twice.
Old 06-01-2007, 09:15 AM
.T.
.T.'s Avatar
Temporary here but, where'd you find that detailed info?
Old 06-01-2007, 09:21 AM
tdrumm's Avatar
Using a + for deck height in my calculator makes the CR even lower, still not sure how you are getting 10.3:1??
Old 06-01-2007, 09:46 AM
Unported LS6 heads milled down to 58.8cc chambers with a 3.910 bore x .045 thick gasket on a stock 5.3 shortblock will net you ~10.0:1 compression.
And, I misread this... I saw 3.910 bore, not 3.910 head gasket diameter.
Old 06-01-2007, 10:17 AM
tdrumm's Avatar
That'll do it.
Quick Reply: 5.3 vs 243 Heads...Confusion
